Jeff Mitchell's RV8 project
Date:  9-21-2008
Number of Hours:  4.50
Manual Reference:  7-7
Brief Description:  Fabricated corner fillers and more prep work.
I decided that the holes left at the aft corners where the baffle and the end ribs were just a bit large to depend on sealant alone to fill. So, I fabricated a couple of small pieces that will be riveted in place which fills up a lot of the hole. I also continued with more preparations for the rear baffle installation. As a bonus my pressure regulator (at the hose end) failed so I replaced it with a new one and will do a leak check first thing tomorrow.
Giant hole to fill
Giant hole to fill
.040 sheet fillers in place
Much less space to seal
