Jeff Mitchell's RV8 project
Date:  9-15-2008
Number of Hours:  2.90
Manual Reference:  7-7
Brief Description:  Left tank fuel vent line and fittings.
I spent some time carefully bending the fuel vent line then flared the end using my new flaring tool from ATS. I lightly tightened things in place to check for fit. I still have to bend the end of the fuel vent line up so it is positioned at the highest point of the tank and will set the B-Nuts down to the proper torques once I rivet the most inboard rib in place.
I still have to bend it up higher
New tube flaring tool
Fuel vent fittings in place
