Jeff Mitchell's RV8 project
Date:  9-10-2008
Number of Hours:  2.50
Manual Reference:  7-7
Brief Description:  Tank anti hang up and float sender wire.
I fabricated the anti-hang up that goes between the stiffener and the second rib. I decided not to use this one because I think I can do better if I try again. I will cut some more .040 at work then repeat the process. I did manage to bend the float sender wire to shape. Don't forget there is a right hand and a left hand sender unit and there is a 3/4" bend at the end of the wire that goes through the sender unit. Look closely at the supplemental plans sheet that comes with the senders.
Anti hang up
Anti hang up
Decided not to use this one
Float sender wire bent to shape
