Brief Description: Started on T-405 tank attach angle bracket.
I spent 20 minutes deburring the rivet holes in the tank stiffeners then got started on fabricating the T-405 angle brackets that will attach the fuel tanks most inboard rib to the fuselage. I used my band saw to cut a piece to 3 3/4" then marked it up as indicated in drawing 16A. I'll finish these up tomorrow.
