Brief Description: Countersunk span wise rivet holes in right tank.
I countersunk the span wise rivets that will attach to the main spar. Don't forget NOT to countersink the baffle, just the skin. Then I used progressively larger diameter drill bits to final drill the tank attach screw holes to a #19.
