Brief Description: Finished left wing splice plate.
I drilled the holes for the rivets that secure the nut plates to the W-423 splice plate for the left wing. I deburred and dimpled as required then set the rivets securing the nut plates in position. I clecoed it onto the leading edge assembly to ensure a proper fit. I also enlarged the Z-Bracket bolt holes in the main spar flange to make it easier to get the bolts started if I should have to remove the tank in the future.
