Brief Description: Pitot tube installation - Part 3.
I installed the AN fittings and brass ends onto the A of A and ram air tubes from the Pitot tube. Then I pulled the black conduit, green pitot and blue A of A lines through the wing ribs. I finished up by installing the Dynon Pitot tube heater controller on to the inspection panel that resides above the bell-crank assembly. There is plenty of room between the two with no chance of interference. I figured this installation location will make it easy to access the controller in the future.
