Brief Description: Match drilled / bent replacement HS-810-1.
I match drilled and machine counter sunk my replacement HS-810-1. Tapered the ends and bent them as specified in the plans. I clecoed it in place and match drilled the outboard ends. I have to back drill the two holes that go through the HS-405 main rib. I can't do these until I receive my angle drill from Cleveland Tools.
