Brief Description: Riveted VS rear spar, doubler and hinge brackets.
I used my Main Squeeze and aligator type pneumatic squeezer to rivet the VS doubler, rear spar and hinge brackets together.
Only had to drill out two bad rivets. My pneumatic squeezer is nice once it is set up correctly but takes me a long time to get the die and shim combination correct.
