Brief Description: HS rear spar hinge bracket installation.
I riveted on the rear spar brackets and bolted on the center bearing assembly. I had to drill out and replace only one bad rivet on the brackets (smiled it). All in all I was happy with the final result. Only 2 bad rivets on the whole rear spar assembly!I can't continue with the HS skeleton because I am still waiting for the replacement rib and front angle piece from Vans.I might start the VS next.
