Brief Description: Primed HS rivet lines and other HS parts
I cleaned and re-primed all the HS ribs and spars. Then primed the insides of the HS skins. Removing the vinyl was a bit difficult so next time I think I will just spray the rivet lines without any vinyl left in place on the inside of the skins.I decided I wanted an extra layer of corrosion protection on the non Alcladed aluminum parts. After some research I settled on AM 100 high quality clear coat by 'R-M'. This is a very nice product and goes on like glass. It leaves a smooth, hard and shiny layer right on top of the primer.
