Brief Description: Deburred and fluted HS skeleton assembly
Deburred all edges and fluted all ribs of the HS skeleton assembly. This was very time consuming and not all that exciting. I clecko'ed the skin onto the skeleton in order to mark the rivet hole location on HS-404 and HS-405. I then made very shallow flutes between each mark so I can include these ribs with the other parts in the priming planned for tomorrow. I will finish flutting these parts once the holes are drilled into them.
