Brief Description: More work on rudder pedal assembly.
I still don't have the vent line tubing I ordered so I continued work on the rudder pedal assembly. I got the blind rivet installed that holds the F-8107 collar in place at the front end of the slide tube and I match drilled through the F-874 Delrin blocks and inserted their nuts and bolts. I finished up by separating and deburring the parts that make up the F-8103 release assembly.
