Brief Description: Andair fuel valve installation part 1.
Like most others I am using the fuel valve from Andair instead of the stock valve. I decided to use 1/8" thick aluminium flat bar for the main structural support of the support plate. This gives me good access below. I used the Andair template to mark out the 4 holes in my support plate then drilled them out. Once I was happy with the positioning I clamped the support plate into position and made some marks.
