Brief Description: Match drilled seat rib Subassembly.
I fabricated the F-805D brackets from 3/4 X 3/4 063 angle as per DWG 65. There were three 12' lengths of this angle shipped with my wing spar crate. It took me about an hour to determine that these angles are NOT used as longerons for the fuselage. I have no idea why they sent me so much of it, but its better too much than not enough. Then I match drilled all the seat rib components to each other and finally to the two center bottom skins.
