Brief Description: Dimpled Aileron skins and stiffeners.
I used a Maroon Scotch Bright pad soaked in Lacquer Thinner to rough up the inside surfaces of the Aileron skins so the primer will better adhere. Then I employed my DRDT-2 on the Aileron skins and stiffeners, and then I started to debur the edges. I will do the final smoothing tomorrow with a small SB wheel on my Die Grinder.
