Jeff Mitchell's RV8 project
Date:  1-22-2009
Manual Reference:  7-8
Brief Description:  Pressure tested right hand fuel tank.
I installed the tank pressure test kit from Van's and used my bicycle pump to pressurize it. I sprayed every rivet and seam with soapy water and checked for bubbles using a very bright light. No leaks detected! Then I rinsed the outside, let dry, did a final cleaning and primed the aft baffle and outboard rib.
Right tank pressure test - no leaks
Primed and ready for final installation
