Brief Description: Fabricated corner fillers and more prep work.
I decided that the holes left at the aft corners where the baffle and the end ribs were just a bit large to depend on sealant alone to fill. So, I fabricated a couple of small pieces that will be riveted in place which fills up a lot of the hole. I also continued with more preparations for the rear baffle installation. As a bonus my pressure regulator (at the hose end) failed so I replaced it with a new one and will do a leak check first thing tomorrow.
