Jeff Mitchell's RV8 project
Date:  8-27-2008
Number of Hours:  5.50
Manual Reference:  7-6
Brief Description:  Worked on Fuel Tank access plates.
I worked on the required modifications of the two most inboard tank ribs (left and right tanks). I am installing the inverted fuel system flop tube in the left hand tank and the standard fuel pickup in the right one. I used a fly cutter to cut the large access hole for both tanks then used a Uni-Bit to drill the 7/16" holes for the vent lines. Next was to clamp (I don't have 5/32" cleco's so I just used some of the access plate screws and some nylon lock nuts on the back to protect the threads) the T-708 (for the standard pickup) and theT-411 plate( for the tank with the flop tube) to their respective ribs and match drilled the screw holes to #19. Then I used the T-407 rings to back drill all the nut plate rivet holes. I deburred all the holes, rings, and access plates. Finishing up for the day I measured and marked some 0.020" and 0.030" scrap for the trap door, vent clips and anti-hang up bracket. I will bring them into work tomorrow and use the shear to cut them out.
Fly cutter setup
Fly cutter setup
Clamped in place ready for back drilling
Drilled, deburred and ready for countersinking
