I continued working on getting the skirts to fit nicely around the fuselage at the aft end of the canopy. As you can see in Image 2 there is a bit of a gap just right of the canopy slide rail, but I applied some heat to this area and gently bent this corner down better matching the gap on the left side. I will apply some Micro Epoxy in the area to improve the fit even more. Overall I managed to get a descent fit between the skirts and the fuselage.
