Brief Description: Flap installation and rigging - Part 3.
I did more fiddling with the flap actuator push rods. I have the left flap set up now and need to remove the right hand flap one more time to trim a bit of the skin at the top inboard portion and to lengthen the pushrod just a bit. I also wired a momentary toggle switch (ON-OFF-ON) to the flap motor to make it easy to raise or lower the flaps.
