Brief Description: Wing alignment and incidence setting.
I leveled the fuselage then aligned the wings and sweep and clamped the rear spar in place. I had to make a few slight vertical adjustments to the aft spars position to set the wing incidence. Next up is to install the flaps and check their interface with the fuselage bottom.
