Brief Description: Manual trim and air vent holes drilled.
I used a fly cutter mounted in my drill press turning at 500 RPM to cut the air vent holes in the instrument panel sub-panels. I also drilled the 3/4" hole for the manual elevator trim control. I removed the rubber cap and pulled out the plunger disabling the course adjustment feature. I'm still looking for a suitable 1" chrome cap.
