I installed the tail spring into WD-409 and then installed the tail wheel fork into the WD-101 FSTW mount base. I used a 3/16" and 1/4" reamer to make the holes for the attachment bolts fit perfectly. The tail spring fits very well with no play whatsoever. I thought this was going to be much harder than it turned out to be.
