Brief Description: Aft Upper Skins and Bulkheads - Part 2.
I clecoed on the aft upper skin and match drilled the bulkheads and the F-882 canopy rail receptacle to it. I had to remove some material at the bottom front leading edge of the vertical stabilizer because it interfered with the F-825 aft skin. Then I aligned and clamped the two F-869 gussets in position. I just had to check the fit of my Fairings Etc. empennage fairing which is near perfect.
