Examined the instrument pod and found several areas that needed sanding. Not sure if the ridges are supposed to be there (Pics 1 and 2) but sanded them down and ended up with more imperfections. Used Marine Tex to fill in the imperfections. Should be cured by Tuesday and then will sand the entire pod down. I cut the the holes in the instrument pod where they were supposed to go but they didn't line up (3rd Photo). I will fill in the larger holes with fiberglass.
