Started work on finishing up instrument pod. Decided to mount and secure pod using four bolts (AN3-5) with nuts and washers. Wasn't sure as to how well fiberglass pod and metal instrument stand were going to work, so I put in a 1/8" silcone baffle seal between the two. This should prevent any rubbing between the two materials and hopefully to dampen any vibration. Once the pod is finished, I will use a set of four cushioned clamps on the 2 posts inside the pod to further secure the pod.
