Brief Description: Construction of Battery Compartment
Drilled 4 holes on each lip of battery box. I used the same holes to mark the same location on the floor board for the rivets.. I used clecos to hold of the box and everything looked good. Had to do some minor adjustments to the opening so that the door would rest on the sides of the battery box. I sprayed the inside and the outside of the battery box with black bed liner spray. Waiting on piano hinge from Aircraft Spruce to attach door to floor.
