Brief Description: Build pitch trim and autopilot harness
Build the pitch trim harness. The photo shows the pitch trim motor and autopilot harness attached to the Molex connecor. The wires would be removed from the connector to be fed through the holes prevously mentioned and mated up at the connector. I am using fiberglass sheathing to protect the wires in the run through the fuselage. No major power wires run inside this connector. The strobe and position light power wires will be run in a different connecor routed on the other side of the tail to prevent interference with the delicate and important autopilot and trim controls.
