Set the vertical stabilizer up just to mock it up. After setting up to make sure it was straight I decided to go ahead and drill the rear holes. Drilled and colecoed both holes. Remeasured the VS and found even with the clamps in place the VS had moved! I now had 1/4 inch lean to the left! Dang!!! Oh well I'll just have to live with it. Mounted the rudder just to see the tail somewhat complete. The hinges did not line up and the front joggle plate needed to be cut down slightly. Ok, done for the night. Slightly depressed.
