Jims Web Site
Date:  1-9-2011
Number of Hours:  2.50
Brief Description:  Install fuel lines to selector valve
I worried about the fuel line install because the lines must go through one of the brackets that doesn't come out. With the wings on I needed to plan enough material to go through to the tank and still be able to get to the selector. With bends at both ends it needed to be very close. I eyeballed the amount of pipe and started with the 90 degree to the selector. Then worked my way over to the tank. Reworking the bends was a lot easier than I thought it would be. I could shift the bend a little farther or closer as needed. Getting the 90 deg in the corner and then the 90 deg. through the fuselage was tricky but not really all that hard. Estimating where to cut off the excess was really the hardest part. The first one took at least 1.5 to get right.
The left side I started with what I though was the same length pipe as the right side. Again bent the selector and worked my way to the tank. After the bends, the pipe was exactly the correct length to mate up to the tank. Boy it was close, could have really screwed up, but it all worked out in the end. Talk about clean living.
