Jims Web Site
Date:  12-16-2010
Number of Hours:  2.50
Brief Description:  set flap travel and ailerons
Installed the new correct flap rods and set travel. This worked much better. The flaps retract almost flush to the fuselage and travel to 38.5 degrees. I have the side to side angles to within .2 degrees of each other.
Adjusted the ailerons to the correct center trim level as per plans. When I made the rods I held the tolerances very close to the plans. After installing the rods into the wings I set up the aileron centering tool made earlier. I checked and checked and the control sticks were vertical and the ailerons were exactly in the center of the tool! What a great kit. Build to the correct tolerances and it really does work.
