Started the crate for wing transport. Cut the upper MDF for the leading edge. Mounted the 1 x 4s one one outer edge. The other side cannot be installed at this time due to the posts being in the way. I will make just the outside frame first then lower the wing to the ground and finish the other side. Cut the lower MDF parts to hold the wing in place. These lower parts will end up on the top when finished. The lower pieces will end upward when done so they will just locate and steady the wing once in the cradle.
