Install pitot tube, tighten fittings and run the wires. I am using knife connectors mounted in place with an adel clamp mounted on the bellcrank assembly. The wires will be readily available if necessary to remove the pitot. The fitting is accessable also through the hole and when disconnected the pitot will easily slide out the mounting bracket.
