Brief Description: Proseal trailing edges of elevators
Pro-seal trailing edges of left and right elevators. I mounted the elevators to a piece of wood by drilling throught the rivet holes. Then colecoed the elevator to the board. Pro-seal is nasty stuff, It pays to keep everything clean while working with it. I smeared a thin coat on each side of the trailing edge filler and colecoed it all to the board. I will let this set for a couple of days to harden.
Prep the trim tab parts. Debur edges of all parts. Spent a lot of time making sure I understood how to assemble the trim tab. Many people have not had good success in doing this part correctly so I want to make sure I understand the process.
