Brief Description: Mount vent pipe, fuel pickup, sender
Installed the vent pipe into the fuel tank. Mount fuel pickup onto the end plate. After making the pickup for the right tank I decided that the pickup tubes Vans offered whould be much better. So I bought a pair. I like the screened end so much better then the cheesey way Vans wants you to cut, fold and sawtooth in the plans. I will go back and change the pickup in the right tank later. Bend fuel tank sender float wire. Set the float levels and check the ohms from the sender. All good!
