Fabricate right wing tie down. Cut, drill, tap, debur, mount. Once again so many steps and at the end of the day dang little to show for it. Progress just seems slow. Each step is one more towards completion. The worst part of it is after I fabed both mounts and installed them it just didn't look correct. Based upon the dimentions given by Vans the mounts don't 'center' within the holes provided. I could have made them centered but I am following the directions, I have learned not to read too much into the process of building. If it becomes clear later I will redo them.
