Modify the pitot line in the wing. I decided to cut the line back to the second rib in and install a bulkhead 90 deg. fitting. This would be a good place to terminate the hard line. Then I will make a rubber line to make a nice bend and mount to the fuselage with another bulkhead fitting. Once inside I will figure out how to get to the panel. With lots of room in the floor I don't think it will be a problem to figure out how route the tube.
