Trim tab took more work than I was hoping. I had misplaced the Al tab arms and had to make then out of sheet metal. Spar was adjusted and riveted in place. The parts were primed. A long brake was taken to wiat for the Al Plate to come from Van’s. I had over looked the spar plate and the trim tabes in the inventory list. After finishing up, I glued the foam inplace and closed the tab. The hing ws grilled in place and riveted on both sides.
