Brief Description: Installing the rudder and brake pedals
Rudder pedals were built and installed in this section. The foot pads were riveted to the angle aluminum. They were installed in the pre-make brackets / blocks. The bearings holding the pedals were build up and match drilled to the longerons. Mid-section bearing were also build and installed. Note that I chose the option for both sets of pedals to have brakes. They were both installed in this section.
