JAMES'S WEB SITE
Date:  1-20-2006
Number of Hours:  14.50
Manual Reference:  Pg 6-9
Brief Description:  Building the Trim Tab
Trm tab took more work than I was hopping. I had misplace the Al trim tab arms and had to make them out of sheet al. Spar was adjusted and rivetted in place. The parts were primed. A long brake was taken to wait for the Al Plate to come in from Van's. I had mover looked spar plate and the trim tabs. After finishing up them up and starting up again I glued the foam inplace and closed the tab. The Hing was drilled inplace and riveted on both sides.
Adjuster arm
Adjuster arm
Foam 'rib' before gluing implace
Hing drilled rivetied and ready
