I made wing stands and a tail stand based on the blueprints that came with the kit. The wing stands are canted slightly to match the wing's angle of incidence. All were filled, sanded and painted to match the work tables.
After the rear half of the rotisserie got hung up on the lip of my hangar floor and tipped over (which put a hole in the underside of my left horizonal tail), I decided to connect the two halves of the rotisserie together. A matching piece of 2" square steel tubing was used with some angle iron braces and hardware. That mod made it much easier to move the airplane around by myself and it's a lot more stable.
New wing and tail supports.
Notice the tail sling from the ceiling.
I connected the two halves of the rotisserie so it was easier to move.
