After curing, the weights, clecos and clamps were removed and all the remaining holes were filled with micro/flox mixture. The leading edge joggle was filled with micro and then sanded smooth after drying in order to make sure no air bubbles would remain under the leading edge layup. A 3 BID carbon layup was applied over the leading edge of each wing. Fiberglass was used for the layup over the wingtips. Peel ply was used as always.
