Legacy N222BZ
Date:  3-22-2004
Manual Reference:  Sec 2A
Brief Description:  Bonding fuselage to wing center section.
The center wing section was bonded to the fuselage using flox and proper bonding techniques. Clecos were used all along the leading and trailing edges and spaced approximately 2-3" apart. Clamps were also used where required to get the proper squeeze out for a good bond.
Center section leading edge clecos.
Trailing edge clecos into the fuselage.
Clamps were added as required during bonding.
