Wiring diagram for the AERO LED lights. Each light has 5 wires but a different wiire is capped off at each end. Will use the 4 of the five wire bundle. Will bundle the two white wires together as ground. The attached diagram details the plan wire color. As noted in a previously the plan is to connect everything while the wings are temporarily installed leaving a service loop. The service loop will then be cut when the wings are removed for transport and wires reconnected at the airport prior to test flights.
