Today, I began by adding some baffle material to the Vans Air Box, to better seal it against the inlet. Next, I spent some time adding some Bostick 1100 to the window frames. When I initially used the 3M auto windshield stuff, it didn't flow out and left a gap at the edge of the window frame. Today I filled the gap. What a mess! Good news is that it cleans up with Alcohol. Then I turned my attention to the tail. A bit of work on the fin fairing, then I removed it and added a washer to the tail stinger. It had just a bit of left to right wiggle and a thin washer took care of it. Finally, I worked on the three access panels on the lower tail cone. I added some Rivnuts, and in one case made a cover plate -- not real happy with it and will likely do it over tomorrow.
