This morning, I worked to resolve the electrical issue I found yesterday. Turned out there was no issue, I had installed four dimmer pots but only connected three. The fourth is for future growth. That's why we write this stuff down! I also spent some time cleaning up the shop.
Then, after lunch, I began the nasty job of sanding the seam along the top of the dorsal fin I had mated earlier. Ugh -- I hate sanding fiberglass. But, it turned out really well. I used some spot putty to fill in some scratches, and then sprayed high build Rustoleum auto primer on the seam. There are only a few areas I will need to touch up.
Monday is a flying day and working on the Cygnet in the hangar.
