Today, I spent quite a bit of time finishing off the left door lower corners, then I riveted the floor in place along with the baggage compartment floor corner panels. That is, until I ran out of the right lenght rivets! So, on to the flap controls. I mounted the two flaps, and then riveted the control horns onto the two end caps. And, began to fix the left one in place. Will continue work on them today.
