Today, I finished assembly of the adjustable wing stand. My plan is to have guys help to lift a wing up into the air, slide the assembly under the wing, and then I can manuever it from there. The adjustment function will help me to set the incidence on the wing. I also made a fixed stand, you can see it in the background on the third picture. Once adjusted, I will put the fixed stand in place and dissasemble the adjustable stand and move it to the other side for the other wing.
