Today, I worked hard to complete my elevator cable installation. Not as easy as it seems. First, I removed the delrin block I had cleco'd in place and cut slots so I could replace it if necessary. I then riveted it in place. Finally, I worked to fabricate the elevator cables, with the turnbuckles positioned just aft of the cargo compartment. They will be easier to reach than buried in the tail. For the flap cable, I'll install the turnbuckle on the vertical rise of the cable at station D.
